94 dodge truck wont move in neutral ,engine on or off
Old Jan 30, 2017 | 04:44 PM
daniel1975's Avatar
daniel1975
Default 94 dodge truck wont move in neutral ,engine on or off
I Own a 94 Dodge Dakota 4x4 v6 and the strangest thing happened. I turned on the truck in the morning to go to work and I shift it in reverse and it leaps forward. I step on the gas and it will not move at all...rpm's rev up but it will not move..i put it in drive and it will move very sluggish. I shift it in neutral and push my truck backwards and it wont budge, it feels like its in park.
I turn off my truck and shift it to neutral and truck will Not move at all even if I get two own men to push it back. its Stuck...
4x4 will not engage ( manual shifter )
please Help
deltaecho1975@yahoo.com
Old Jan 30, 2017 | 06:28 PM
Brake hanging up? Trans trashed? Shift linkage mis-adjusted?
Old Jan 31, 2017 | 01:40 PM
daniel1975's Avatar
daniel1975
I lifted the differential and took off the driveshaft....wheels turn freely
linkage looks good....unscrewed linkage and tried to shift the 4x4 manually and it was stuck...transmission linkage is working properly , manually and it being connected ..
I am going to take off the transfer case to once an for all eliminate the possibility of being either the transfer case or the tranny being the problem....
what do you think ?
Old Jan 31, 2017 | 08:01 PM
volaredon's Avatar
volaredon
something screwy in the valve body, or rear band too tight... the "put into reverse and it went forward" gives that away.
weird though that it would not roll in neutral with the truck not running.
the sluggishness when put into drive says that either the torque converter has issues or, again the valve body.
Old Jan 31, 2017 | 08:15 PM
daniel1975's Avatar
daniel1975
Default I found the problem
Took off the transmission Drain pan and I found a **** load of transmission parts inside ...
Also a **** load of metal shavings ..😩
Oh well
Thanks anyway
Let's see if I can upload pics
Attached Thumbnails 94 dodge truck wont move in neutral ,engine on or off-img_5739.jpg   94 dodge truck wont move in neutral ,engine on or off-img_5740.jpg   94 dodge truck wont move in neutral ,engine on or off-img_5741.jpg
Old Feb 2, 2017 | 06:01 AM
robertmee's Avatar
robertmee
Ouch....sorry to see that...On a good note, the Gen 1 transmissions are fairly plentiful at the junk yard.
Old Feb 2, 2017 | 01:38 PM
volaredon's Avatar
volaredon
Looks like the needle bearings out of a thrust bearing and alot of clutch material. I'd rip it apart just to see though I have been inside of these transmissions myself many times, just rebuilt the one in my 96 last week, doing my spare this weekend being as how OD seems to be trying to die in the transmission that is under my 92. Not bad though that one has 187k on it and it hasn't been touched besides a couple of filter and fluid changes since new.
