1996 factory service manual
Old Mar 3, 2017 | 01:49 PM
Isaac95sltv8magnum's Avatar
Isaac95sltv8magnum
Default 1996 factory service manual
Is a 1996 2wd 4wd factory service manual good for a 1995 dakota?
Old Mar 3, 2017 | 02:12 PM
RalphP's Avatar
RalphP
Yes and no. Depends on what part; electronically, the 1996 is almost completely different (switched from SBEC to JTEC; switched from OBD to OBDII; added the downstream O2 sensors; automatics went fully electronic in 1996, whereas they were hydraulically controlled for all but OD and lockup in 1995; etc.) Most of the chassis stuff stayed the same.
Edit: Check the sticky at the top (the first of the two FAQ stickies); you'll find a 1995 PDF there.
RwP
Old Mar 3, 2017 | 04:17 PM
Isaac95sltv8magnum
Thank you will do!
