Pulling the transmission
Old Mar 29, 2017 | 02:30 PM
dakota1996's Avatar
dakota1996
Originally Posted by 93 ragtop
Thanks for your reply. Did you have to take the torsion bars loose to drop the transmission mount?
I believe the 96 and 87 have a slightly different crossmember. Another member (ragged 89) told me I would need to weld a tab on the existing crossmember. (87)
No I did not need to remove torsion bars. Ifu knock it back far enough it will turn and u can just angle it out of the Truck. And I'm not real familiar with the older models I'd have to take a look at them.
Old Mar 30, 2017 | 12:40 AM
Curtis Edge's Avatar
Curtis Edge
I did not have to remove my torsion bars...although I did hit my head on them several times. I'm talented.
Old Mar 30, 2017 | 07:33 AM
93 ragtop's Avatar
93 ragtop
Well yesterday, I only got to work on it for a few hours. But, I pulled both driveshafts, speedometer cable, vacuum lines, and transfer case.
Today, hopefully I will get the cross member and transmission pulled. Then need to pull the starter, bell housing, clutch and flywheel.
Im a HVAC contractor, so as service calls come in, I have to run them, play latter.
I will update as I go.
Thanks again, for all your help!!
Old Apr 1, 2017 | 08:57 PM
93 ragtop's Avatar
93 ragtop
Got the transmission, clutch, flywheel, etc out. Took longer then I expected. Bad news is, there is oil on the old clutch. I started another post about replacing the rear main seal with the engine in the truck.
Tomorrow, I will try to get some pictures up.
