Oil Leak test
Old Apr 1, 2017 | 10:12 AM
93 ragtop's Avatar
93 ragtop
Default Oil Leak test
Has anyone ever used the method of adding air pressure through the dipstick tube, blocking off crankcase breathers, and pcv valve outlet to check for oil leaks? From what I read, you then use soap bubbles around suspected area.
Just wondering if anyone has tried this.
