Problems with bushings
Old Apr 7, 2017 | 08:48 PM
dakota1996's Avatar
dakota1996
Default Problems with bushings
Okay guys I am trying to get these bushings out but for the upper bushings leave the sleeve bc the energy suspension bushings reuse it. This is proving to be a chore. Tried the drill trick and it did not work for me. Any help is appreciated!
Old Apr 7, 2017 | 08:54 PM
RalphP's Avatar
RalphP
What I did was use a propane torch, heat it up until it started smoking good, and pushed it out with a rod.
The rubber will splatter as you do this, so don't do it on your white 2018 Porsche *grins*
Here's a YouTube video on that:
And here's another one:
RwP
Old Apr 7, 2017 | 09:07 PM
dakota1996's Avatar
dakota1996
Alright I'll give it a go haha wish me luck lol
Old Apr 7, 2017 | 10:16 PM
volaredon's Avatar
volaredon
I have done the propane torch trick with the control arms laying on my gravel driveway, have also done the same when I have brush or leaves burning in the ditch, just throw it in...(Yes I live where they have not yet banned burning yard waste... advantage; living in unincorporated area!)
Old Apr 7, 2017 | 10:17 PM
RalphP's Avatar
RalphP
Luck.
I hadn't seen the drill bit trick, so I did it with my torch.
If you have a MAPP torch, it'll work a bit better.
RwP
Old Apr 8, 2017 | 07:30 PM
dakota1996's Avatar
dakota1996
Alright guys thanks for the help! I got them out using map gas torch. Changing out front axle bearings and seals now
dakota1996's Avatar
dakota1996
Once the arms are blasted I'll be installing energy suspension bushings
