Trans swap question auto to stick
Old Jul 1, 2017 | 12:56 PM
  #21
Toby Warford's Avatar
Toby Warford
Originally Posted by 93 ragtop
Toby,
Mine is a reg. cab long bed 5spd 4wd (1987). The driveshaft is 1 piece. Latter on today, I can give you a measurement of the front driveshaft. (mine is still out of the truck)
Thank you
Old Jul 2, 2017 | 08:23 AM
  #22
volaredon's Avatar
volaredon
ok youre talking front shaft to the front diff, not the front shaft of a 2 piece rear... yeah that will need to be taken care of....
Old Jul 3, 2017 | 03:16 AM
  #23
Toby Warford
Something just dawned on me. I believe I know the difference between the two with mounting and length. On the auto there's an over drive unit attached, but the transmission mount is under the transmission itself. The nv3500 mounts as the auto does, but doesn't have the added length of the od unit. So the transfer case bolts to where the od unit would, and thus the reason needs lengthened and the front needs shorted roughly the length of the od unit.
Ya?
Old Jul 4, 2017 | 12:30 PM
  #24
93 ragtop's Avatar
93 ragtop
Originally Posted by Toby Warford
Thank you
Sorry to take so long getting back. But the front driveshaft, collaspsed, is 22.5 in. center u-joint to the first u-joint,
Hope this helps
Old Jul 4, 2017 | 06:13 PM
  #25
Toby Warford
Hope this helps
Uhh. . What do you mean center u joint to first joint? The front shaft is one piece.. as is my rear..
Old Jul 5, 2017 | 06:18 AM
  #26
93 ragtop's Avatar
93 ragtop
The measurement I was giving is for the front driveshaft. There are 3 u-joints in the front.
Measuring from the splined end u-joint, to the middle? u-joint, it is 22.5 in. The total overall length from center of u-joint cap to the last u-joint cap is 25.5 in.
Here is a picture from ebay for reference. http://www.ebay.com/itm/Drive-Shaft-...FZNJl0&vxp=mtr
My intentions with this post was to help to decide if the transfer case is in the same position on a manual transmission vs a automatic.
If there are any other measurements or pictures I can take that will help let me know.
Old Jul 5, 2017 | 12:35 PM
  #27
Toby Warford
Thanks. I'll measure mine and see what's what. I think I have it nailed down now.
Old Jan 29, 2018 | 01:49 PM
  #28
Snowman451's Avatar
Snowman451
3.9, 5.2, 1995-2001. done
Are you aware of any other parts from a 97+ that will work in a first gen? (shifter and pedals specifically)
Old Jan 29, 2018 | 03:53 PM
  #29
93 ragtop's Avatar
93 ragtop
Im sorry, I dont know. But I will say to stay away from the NV3500 that used the electric shift transfer case. It does not have the bosses on the side to mount the np231d shifter (transfer case)
Also, even though the bell housing is the same where the engine attaches, it is different at the bottom where the supports that go from the engine mounts to the bell housing are attached. (on the 4.7 version)
