Tips on mountain driving?
Old Jul 11, 2017 | 02:12 PM
Cash68's Avatar
Cash68
Default Tips on mountain driving?
So I usually road trip out west in a car with a stickshift, but this year I am thinking about taking the Dakota. I'm planning on a fresh set of rotors, pads before I leave, as well as fresh ATF and a transmission cooler.
That being said, what is the best approach for steep, extended, downgrades? In my other cars I just downshift. Experiences?
Old Jul 11, 2017 | 02:27 PM
Drop it down into 3rd or even 2nd depending on the speed and grade. That's what I do. Just to reduce rotor temps by not having tom brake as much.
Old Jul 12, 2017 | 03:28 PM
Toby Warford's Avatar
Toby Warford
You're only worried about the down grades? Don't do anything, leave it in OD and let her coast. Small, short, braking as needed and you'll be fine. Depending on the grade uphill, that's what I'd be worried about with a v6 and automatic.. but, you'll have addressed that by adding the cooler.
Unless you plan to tow something behind you?
Old Jul 12, 2017 | 09:03 PM
onemore94dak's Avatar
onemore94dak
If you feel like the brakes are losing power just down shift one gear at a time. Same deal going up hill, if you're bogging too much and turning off the OD isn't helping, down shift. There are plenty of long steep hills out there you might feel like doing this on.
Old Jul 13, 2017 | 12:32 PM
Cash68's Avatar
Cash68
So for climbing steeper grades, is it best to turn OD off?
Also, I've been searching on the FAQ but I haven't found any really decent transmission cooler guides. Apparently we already have at trans cooler in the radiator?
This is my first automatic in... oh... 13 years... so I'm a bit lost with automatics. Lol. Do I need a gauge too?
Old Jul 13, 2017 | 03:46 PM
I think you are over analyzing it. Just drive.
Old Jul 13, 2017 | 05:04 PM
onemore94dak
jKeaton pretty much has it all covered.
I remember being very ignorant and not having anyone to ask so.....turning off the OD simply drops the trans back into 3rd gear. That will give more torque on uphills if its really lugging. Really most roads are properly graded and these trucks when in good shape can handle any paved roads.
Old Jul 13, 2017 | 11:55 PM
Toby Warford
Uh.. it's an automatic.. it'll down shift when it's right to do so.. there no need to turn off od unless he's towing something..
My over weight v8 4x4 can keep 70mph in od unlocked torque on a 7% grade for 1.5 miles pretty easy.
Old Jul 16, 2017 | 01:42 PM
Cash68's Avatar
Cash68
So in what condition would I ever turn off OD? Towing? That's it? So it's like a towing button?
Old Jul 16, 2017 | 05:21 PM
onemore94dak
You drop it out of OD whenever you want to. It can safely do hwy speeds in 3rd. the OD is mainly for gas mileage. You'll know by driving it. Go find some hills and experiment.
