need oil dipstick
Old Aug 15, 2017 | 07:40 PM
towbar's Avatar
towbar
Default need oil dipstick
My oil dipstick has broken but nowhere seems to have a replacement, they seem to have stopped making it, anyone any ideas where i could get a relpacement.
Dodge Dakota 1994 3.9V6. This is the mopar part # 53020057
Old Aug 15, 2017 | 10:29 PM
Junkyard? Maybe a chrome one from jegs, or summit?
Old Aug 15, 2017 | 10:43 PM
RalphP's Avatar
RalphP
This.
Or both; pick up one from the boneyard, and then use it to set the length on a nice chrome one to the proper depth into the oil pan.
RwP
Old Aug 16, 2017 | 09:33 AM
robertmee's Avatar
robertmee
Originally Posted by RalphP
This.
RwP
Curious, what makes the depths different for various years of the same engine? I have a similar problem. The Crate Mopar 360 Magnum I bought had a center sump oil pan on it which of course wouldn't clear the x-member. So I went with a Durango 2000 Pan which fit perfectly. The Durango Pan is much shallower, so the oil pickup/level is different. Unfortunately, I have a v-belt setup, and the stock Durango tube/stick kicks it out to the left past the serpentine position of the Durango Alternator. I need one that goes straight up inside the V-belt Alternator position (the mopar crate tube is like this). Right now I have the short 3.9 stick stuck in there just to plug the hole, but I need to get a stick and/or tube. What would be the best route to get the correct length without dropping the oil pan?
Old Aug 16, 2017 | 09:39 AM
Change your oil and filter. Pour in the required amount of oil, run the engine enough to build oil pressure, let it sit for a couple minutes, (engine off) check your oil. See where it's at on the stick, and take it from there. The important thing is, that there is the proper amount of oil in the engine, not how accurate the stick is.
Old Aug 16, 2017 | 11:48 AM
onemore94dak's Avatar
onemore94dak
OK I think I posted this for someone else. Maybe someone can sticky this information somewhere? I took my dipstick out and measured it.
94 Dak 3.9- Oil dipstick from base of T handle to tip is 32 inches. The add line is 1.5 inches from the tip and the safe line is at 2.5 inches from the tip.
I am assuming no one has replaced my dipstick before I purchased the truck.
Old Aug 17, 2017 | 08:07 PM
towbar's Avatar
towbar
Thanks for all the help, I will make one myself but I have to get the broken part out first
Old Aug 17, 2017 | 09:31 PM
Oh, that's always fun.......
