How do I disconnect the trans lines from radiator 1994?
Old Sep 30, 2017 | 08:25 AM
ba_50's Avatar
ba_50
Default How do I disconnect the trans lines from radiator 1994?
It is a 1994 slt 3.6 Dakota. How do they come off and how do I prevent trans fluid from drainng? Thank you.
Old Sep 30, 2017 | 08:29 AM
Need the special tool. Most parts stores will sell them. I think it's the 3/8ths that you want.
Old Sep 30, 2017 | 08:51 AM
ba_50's Avatar
ba_50
how does it work? Are the clips reusable?
Old Sep 30, 2017 | 09:03 AM
Put the tool around the line, slide it into the connector, push the connector ON a bit more, while pushing the tool into it, then the connector should just slide right off. (tool stays in place... it doesn't go with the connector.) To put it back on, just push the connector onto the line until it clicks. Done. If it isn't currently leaking, nothing else needs to be changed.
Old Sep 30, 2017 | 10:37 AM
onemore94dak's Avatar
onemore94dak
I got a tool at NAPA. I had to grind down the side I used because it extended too far to fit between the rad and the fitting. It worked fine. Found my old post with pictures https://dodgeforum.com/forum/1st-gen...-question.html
