Anyone have exh manifold stud part numbers?
Hey all
Found my exhaust leak today, the driver side manifold studs are both broken. The bolts in the front flange are ok but the rear studs are gone. One stud gone also on the passenger side.
If anyone has the OE part numbers for the studs, washers and bolt or the part number for a Dorman (or other maker) repair kit please let me know.
Thanks
Steve
Thanks
Steve
When mine failed, I took a caliper, measured how deep the hole in the block was, measured how thick the exhaust manifold was, and got a set of studs that were 1/2" longer (to give me enough for the nut on the outside!)
My 1988 with the LA 3.9 used 5/16-18 studs.
THAT said - ARP has some "header studs" that are extra long (for headers) for small block Mopars; they should fit and work. DO verify thread diameter and pitch, though; the Magnums may be metric, not SAE thread.
Can't help much past that.
RwP
RwP
Thanks guys, can't seem to find anything online that references them so I'll just go with the dealer on these. I was surprised to see them broken, is this a common failure point on the 3.9? I will admit that the bolts don't look very good either, probably should just replace all of these on both sides. Going to see if I can get by with just doing the driver side this year though, lots of other things to fix on this and manifold studs was something not on the list of fixes.
Steve
Steve
