Limited Slip Differential
Old 12-22-2017, 07:16 PM
bronze's Avatar
bronze
bronze is offline
Originally Posted by 93 ragtop
I have a 8.25 sitting in my driveway..... Its 10 bolt cover and if you measure from the top bolt to the bottom bolt, it is about 9.5 in. I would "think" a 7.25 would be about a inch less. FWIW I doubt mopar ever put a 7.25 in a 4wd v8 dakota. I bet yours is 8.25
Thanks Ragtop. I have the 10-bolt so per your insight it is probably the 8-1/4. I have rear drive only but have the 318. like you.
Old 12-23-2017, 12:35 PM
RalphP's Avatar
RalphP
RalphP is offline
If you have the cover off, post a pic.
Originally Posted by Toby Warford
what? No. Why would you tell him that?
Op, jack the rear end up. Turn the tires while in neutral. If they spin the same way, its an LSD. If they spin the opposite way, its an open diff.
Because the cover is off if he's changing the fluid; it's even easier to look with it off.
Also, a FAILED LSD will act like an open; so it's not a solid guarantee if they spin opposite directions (failed as in clutches shot, no limiting of the slip).
(I need to get my spare pumpkin for my Cougar rebuilt with the new gears; the 3.08 LSD in it now has failed due to age and poor maintenance in the past.)
RwP
Old 12-25-2017, 12:05 AM
volaredon's Avatar
volaredon
volaredon is offline
that is an 8-1/4 I can tell by the pic of what's visible of the cover flange part of the housing last winter when I got my 96, I rebuilt mine and used that as an excuse to add a Track Lok to mine because I had one sitting here....
Quick Reply: Limited Slip Differential
