95 Dodge Dakota lift kit.
Old Jan 24, 2018 | 10:27 PM
WeldermanAZ's Avatar
WeldermanAZ
Default 95 Dodge Dakota lift kit.
Does anybody have any idea on who makes or what you can do to put a lift kit on a 95 Dodge Dakota. I had some people say that it's a front axle swap going to a solid axle is this the only type of lift kit swap there is for the style of Dakota.
Old Jan 25, 2018 | 12:42 AM
tbugden's Avatar
tbugden
Check the FAQ here: https://dodgeforum.com/forum/1st-gen...ion-ideas.html
But yeah basically there's nothing bolt-up that you can do. Crank the torsion bars is about it. If you want more you need a solid front axle.
Course a body lift is easy and basically the same as on any truck, personally I have no idea how high you can go before you have to lengthen the steering shaft.
Old Jan 25, 2018 | 10:52 PM
Toby Warford's Avatar
Toby Warford
Body lift 3"
crank tbars and rear blocks another 3"
larger tires 2-3" more
You can get the truck itself 7" higher then stock. Give or take.
Old Jan 26, 2018 | 10:44 AM
tbugden's Avatar
tbugden
Cranking torsion bars might not get you 3 inches. Maybe, but only if your torsion bars were set on the pretty low side to begin with. Fully cranked torsion bars will approximately level the truck and 3 inch rear blocks will restore the factory "raked" look and then some. Truck will look pretty rear-end high.
Old Apr 23, 2018 | 07:39 PM
Bowdrier's Avatar
Bowdrier
Im in the process of installing a 3 inch ebay lift, 3 inch blocks and new torsion keys. the rear blocks work great and the keys will probably be the same but Im a little worried about the camber adjust ability in the front end. If anyone has info on that Im all ears.
https://www.ebay.ca/itm/1994-2004-Do...t/281780894021 _trkparms=ao%3D1%26asc%3D20170803113400%26meid%3D4 0461d30021f47c7963aa2354de1833a%26pid%3D100275%26% 26itm%3D281780894021&_trksid=p2060778.c100275.m347 4
https://www.ebay.ca/itm/KSP-Dodge-Da...4AAOSw9fRZu5ca
