brake light stuck on?
Old Feb 9, 2018 | 04:14 PM
Cameron707's Avatar
Cameron707
Default brake light stuck on?
I got a fixit ticket for right brake light stuck on at night. With the headlights on when I step on the brake the right brake light is bright and the left is dim. Now with the headlights off smwhen I step on the brakes the left one gets bright and the right one is dim. What could b the problem
Old Feb 9, 2018 | 04:24 PM
Bad bulbs, bad ground, corrosion in the rear wiring harness, (especially if you also have a trailer harness.) etc.
Old Feb 9, 2018 | 04:51 PM
Cameron707's Avatar
Cameron707
Mabe the bulbs but i think its something else cuz the reverse lights arnt working either and the bulbs look good.
Old Feb 9, 2018 | 10:29 PM
RalphP's Avatar
RalphP
Looks don't count.
But yes, I'd be checking the grounds. And the bulbs.
Incandescents are cheap enough I'd just buy a couple of sets and swap them all.
RwP
Old Feb 9, 2018 | 11:36 PM
Toby Warford's Avatar
Toby Warford
So you have a trailer harness? Common issue when these problems arise.
