4 barrel mpi intake
Does anyone know where I could get used HS 1.7 roller rockers? Also would like to put my hands on used 4 barrel multi point injection intake manifold that will fit my 92 dak, 5.2. Any leads would be greatly appreciated.
Are you planning to run the MPI on that 4 barrel manifold? What kind of throttle body setup are you planning for it? Sorry I have no leads on either at the moment, not used anyway.
Yes, that's my plan. So far I've got the modified intake with the plenum kit and ported EQ heads. I got lucky there, 2 brand new never used EQ heads. I figured I wait and see if I can find something used in an intake before I look for a throttle body. I wouldn't be opposed to go carbureted. Do know if my fuel pump can work with one or how to hook it up.
That intake will be expensive and you'll have better luck fimding wooden nickels.
the roller rockers though aren't bad, they're 329.99 maybe a little less brand new. And they're amazing. Well worth the $$.
throttle bodies run about $150 with your core.
straight from the source, John Mercedes at Southeastperformance.com. the guy who worked with Harland Sharp to make them a direct replacement
