1992 Dodge Dakota 2WD v6 wiring issue
I have a 1992 Dodge Dakota LE and I have currently lost headlights brake lights tail lights....replaced headlight switch and nothing....power going to panel and power going to switch....if you remove ALL fuses the dome light stays on
If you don't see 12VDC at the light you're checking, you'll have to follow the 12V feed back to see where you're losing it. Sometimes you'll see 12VDC but when its under load it drops and either doesn't light the lamp or lights it weakly. If that happens, it suggests a weak ground. If the 12V just isn't there, its a break in the wire, a bad switch, a blown fuse, etc. Since you're missing lights all over the truck it might be easier to start your search for a break close to the headlight switch, where you see 12V. Is your bulkhead connector on the firewall tight? All wiring leaving the cab passes in and out through that connector, so wires from the headlight switch to the exterior lights pass through there as well.
