Stereo Part II -- Front Speakers
Old Apr 28, 2018 | 10:28 AM
  #21
RalphP's Avatar
RalphP
Going from the front of a vehicle - the front pillar, at the windshield, is the "A" pillar. As they go back, they're called "B", "C", and "D". My Cougar has A,B, and C pillars; the standard cab has A and B.
Your truck probably has A,B, and C pillars; you'd want to pack behind the speaker while it's out.
This isn't really "car guy" on using Dynamat; this is audio guy, to dampen the reaction of the metal to the sound. (Also helps to quiet the truck out).
And yes, cutting apart makes it a bit less effective. So it's less effective than one piece. It still beats NO pieces ...
You'd be placing it against the inside of the outside of the door; biggest possible problem in the door is, don't plug the drains in the bottom of the door.
RwP
Old Apr 28, 2018 | 12:46 PM
  #22
Ruff16965's Avatar
Ruff16965
Ralph,
Since it looks like disassembly of the rear is not needed, too bad I could of easily Dyamated it all right them to the back wall and I have found some instructions online for removing the seat in the rear.
Old Apr 28, 2018 | 06:29 PM
  #23
RalphP's Avatar
RalphP
Originally Posted by Ruff16965
Ralph,
You could still put some right behind the speaker, stopping the "echo" there *grins*
RwP
Old Apr 28, 2018 | 06:49 PM
  #24
Ruff16965's Avatar
Ruff16965
Ralph,
Have you saw the size of the open and the spaceI have to work with? I think the spray would be the best bet, with my luck on things I would get my hand stuck, or better yet somehow Dyamat myself to the truck. You are talking to someone that at 12 superglued themself to a house trying to fix the shelf they broke while their parents were away and I will not mention the time I superglued my self to my car, 3 times in one day.
Old Apr 28, 2018 | 07:11 PM
  #25
RalphP's Avatar
RalphP
Umm ... Yah, the hole I get to work through on my 1988 is about the same size.
As is the one on my 1991 Cougar in the back.
Biggest secret is to do rolls; it's not as hard as you think it is.
BTW - Acetone will get that superglue free
RwP
Old Apr 28, 2018 | 10:55 PM
  #26
Ruff16965's Avatar
Ruff16965
Ralph,
Even at 12 I knew about Acetone and it getting you free from superglue. However when you have the good furtune to glue yourself to something that, the house or a car, that you can not get to the acetone you are out of luck. At 12 it was both hands as I was holding the shelf in place, figured 5 minutes to really give the glue time to set. I am glad that the neighbor popped in to check how I was doing with my parents gone, I never knew if she told them or not.
Now any time I work with super glue a big bottle of Acetone is right next to me.
Old Apr 29, 2018 | 07:41 AM
  #27
Ruff16965's Avatar
Ruff16965
Okay so between a migraine and a tooth ache I am getting no sleep. So I am wondering the internet, a dangerous thing for me to do, never know what I will start reading and links I will start reading. At least this time it seems safe. Found this in the Metra Catalog about the Dakota, circled it blue.
Now since my door panels are off I am more than happy to confirm the 1993 measurements. Just one question. Where am I measuring?
Old Apr 29, 2018 | 10:10 AM
  #28
RalphP's Avatar
RalphP
Mounting hole to mounting hole.
RwP
Old Apr 29, 2018 | 09:24 PM
  #29
Ruff16965's Avatar
Ruff16965
Afternoon Ralph,
Just getting the message, about 6AM this morning, my security suite goes haywire, so I have been scanning things all day, from the ground up, the computer just now booted up from that. Clean as a whistle thank heavens. I think I am being sent the the grocery store, so I will measure then. Be interesting to see what it comes out as and I will try to get a rough idea of the rear ones. Do screws normally come with speakers?
Old Apr 29, 2018 | 09:54 PM
  #30
RalphP's Avatar
RalphP
Normally speakers come with screws when bought as a set, but I've never had them be the right size for the vehicle.
RwP
