Fuel Pump assembly to tank gasket.
Old May 6, 2018 | 09:12 AM
zhaarnak's Avatar
zhaarnak
Default Fuel Pump assembly to tank gasket.
In the process of converting my 1989 Dakota to an EQ headed, carbureted, Magnum and have run into a problem. I have been unable to locate a replacement fuel pump assembly to fuel tank gasket. The gasket used on my Dak is the flat, black one, roughly 6" in diameter. The only way I can find the damn thing is with the purchase of a new in tankpump (which I will not be using as this will be a carbureted installation). I decided that a new fuel sending unit would come with the required gasket. Maybe it did, but as I cannot find a NEW sending unit anywhere, I am in a tad bit of a jamb. What kind of material (ethanol proof) can be used to make my own gasket/seal? I am sure one of you have had to deal with this.
Oh, one another thing. Who was the inbred, swill guzzling, Draino snorting, HALFWIT that designed the fuel pump assembly for the 89 Dakota? Actually, calling the designer(s) a Halfwit is a grave insult to Halfwits all over the world. I apologize for my rant.....On second thought...NO I DO NOT!
Old May 6, 2018 | 12:02 PM
onemore94dak's Avatar
onemore94dak
This is what I found for the 89 fuel pump https://www.factorychryslerparts.com/showAssembly.aspx?ukey_assembly=625352&ukey_make=1 062&ukey_model=15488&modelYear=1989&ukey_category= 20311
I found this after going through 90-93 finding the nut and gasket are NLA
1994 part 12 in the diagram is what I think you are looking for. I think the tank openings are the same but You'll have to get more knowledgeable people to confirm. If you get one put it in the sun for a while before trying to install and a very light coat of Vaseline on any rubber or synthetic rubber part helps if it is tight. https://www.factorychryslerparts.com/showAssembly.aspx?ukey_assembly=667605&ukey_make=1 062&ukey_model=15488&modelYear=1994&ukey_category= 20311
Old May 6, 2018 | 01:41 PM
RalphP's Avatar
RalphP
Originally Posted by zhaarnak
In the process of converting my 1989 Dakota to an EQ headed, carbureted, Magnum and have run into a problem. I have been unable to locate a replacement fuel pump assembly to fuel tank gasket. The gasket used on my Dak is the flat, black one, roughly 6" in diameter. The only way I can find the damn thing is with the purchase of a new pump. Now, I was not born yesterday, so I decided that a new fuel sending unit would come with the required gasket. Maybe it did, but as I cannot find a NEW sending unit anywhere, I am in a tad bit of a jamb. What kind of material (ethanol proof) can be used to make my own gasket/seal? I am sure one of you have had to deal with this.
Oh, one another thing. Who was the inbred, swill guzzling, Draino snorting, HALFWIT that designed the fuel pump assembly for the 89 Dakota? Whomever it was, should have been locked in a VW van full of half starved Hogs! Actually, calling the designer(s) a Halfwit is a grave insult to Halfwits all over the world. I apologize for my rant.....On second thought...NO I DO NOT!
It's the same basic design to my 1991 Cougar, the 2000 Malibu I used to own, and most all fuel injected vehicles.
What's so bad about it?
As to the gasket itself ... a thick chunk of rubber could be cut into one that fits. Or a cheap fuel pump (I find some as low as $15.27 on RockAuto).
Besides, if you're redoing the motor, I'd do a new fuel pump ANYWAY to make sure it's nice and fresh; hate to have the fuel pump die a week later.
RwP
Old May 6, 2018 | 05:26 PM
zhaarnak's Avatar
zhaarnak
Well, I will not be using the in tank pump. I would have liked to replace the fuel sending unit as I was in the tank anyways. I guess I will just have to purchase the cheapest pump online and then hope that the seal was not made out of pig byproducts.
Old May 6, 2018 | 06:00 PM
robertmee's Avatar
robertmee
I put in a carb magnum in my 90 and kept the in tank pump. Much better setup than a mechanical pump, imo.
Old May 6, 2018 | 09:04 PM
RalphP's Avatar
RalphP
This.
Use an adjustable bypass regulator, get it down to whatever is right for the carb (say 3.5PSI IIRC; DO rely on the carb manufacturer, not my fuzzy-from-age number!!) and let'er rip.
RwP
Old May 7, 2018 | 10:31 AM
robertmee's Avatar
robertmee
Originally Posted by RalphP
This.
RwP
Exactly. My Edelbrock 1406 was happy at 6psi. I kept the return style fuel system of my 90 (upgraded to 3/8" lines), used the inline pump, and the holly regulator here: https://www.jegs.com/i/Holley/510/12...SABEgL3QPD_BwE
Old May 7, 2018 | 08:46 PM
ragged89's Avatar
ragged89
Yeah, the ethanol thing, its a problem if the rubber is submerged or oft exposed.
Permatex makes a sealant called like "aviation form-a-gasket #3", and it withstands all sorts of fuels and additives. I used it to seal new fittings in my tank's fuel module when I put a Magnum 5.2 in my 89.
