Instrument Panel--How Hard To Remove
Old May 31, 2018 | 10:19 PM
Ruff16965's Avatar
Ruff16965
Default Instrument Panel--How Hard To Remove
Evening all,
Was working on the truck a bit ago and had been toying with an idea, to make it work I need to pull the instrument panel, No need to unhook any wires or anything, just sort of swing it out of the way so I can work behind it for 15 minutes or so. It looks like there is just 4 screws at the corners holding it in. Is this correct? Any hidden latches or screws I should be aware of?
Old May 31, 2018 | 10:48 PM
RalphP's Avatar
RalphP
4 screws, and for a 1993, the speedometer cable. If you've gotten the factory service manual already, look at the instrument cluster section; the disassembly changes in 1994, due to the change to the electronic speedometer, so that part isn't in the two manuals in the FAQ, alas.
RwP
