92 Dodge Dakota error codes
My truck
Fuse diagram
Hello I just bought a 92 Dakota and was lies to but I ran the diagnostic and got these error codes.
52 Fuel system rich
34 speed control solenoid circuit
41 generator field not switching properly
33 a/c clutch relay circuit
I also ordered a Haynes repair manual but I'm not a mechanic. I have managed to fix a few things from videos on you tube which was cool but I can't really afford to take it to the shop. Anyone got easy to follow low tech advice on where to start? My is won't switch on except rarely and my abs and brake warning lights are on. I'm pretty sure it's related to the square fuse on the under dash fuse box as it's missing. But can't figure out which fuse to order to fit it. The worst problem is the 13 mpg I'm getting from fuel mix and of of problem. Appreciate any advice.
Last edited by Debra Gerik; Jun 3, 2018 at 09:27 PM. Reason: Wrong words inserted from word prediction
My truck
Fuse diagram
Hello I just bought a 92 Dakota and was lied to but I ran the diagnostic and got these error codes.
52 Fuel system rich
I also ordered a Haynes repair manual but I'm not a mechanic. I have managed to fix a few things from videos on you tube which was cool but I can't really afford to take it to the shop. Anyone got easy to follow low tech advice on where to start? My od won't switch on except rarely and my abs and brake warning lights are on. I'm pretty sure it's related to the square fuse on the under dash fuse box as it's missing. But can't figure out which fuse to order to fit it. The worst problem is the 13 mpg I'm getting from fuel mix and od problem. Appreciate any advice.
See if you can find a factory service manual for your truck, it has a LOT more pertinent information, and it also has accurate wiring diagrams........ something the haynes/chiltons manuals really skimp on.
When is the last time the truck had a tuneup?
Look on Rock Auto, when you get to the page for your truck bookmark it. You should also post what motor you have here. Even if you do not buy a part it makes a great reference for parts numbers and other data. You want the Bishko Repair Manual under the Literature section. You can get the CD for $22.79. This is the Chrysler factory service manual. Read over the FAQ page it contains discussion of the common problems people run into and the solutions they have found.
