Check Engine light
Old Jun 16, 2018 | 09:28 PM
dptropepe's Avatar
dptropepe
Default Check Engine light
Hi. I have a 1989 Dakota 2.5L 5 speed base model with 314,500+ miles. CEL is on, running bad, and running hot. It has codes 12, 24, & 23. How do I go about diaging these codes? Till now, It has been a great truck.
Old Jun 16, 2018 | 10:54 PM
RalphP's Avatar
RalphP
Check the factory service manual and see what those codes are.
Presuming the same as the 1988 2.2, they would be:
12 - Battery Disconnected in last 50 run cycles.
23 - Intake Air Temp Sensor Too High
24 - Throttle Position Sensor Voltage Too High Or Low
That should help some.
RwP
Old Jun 18, 2018 | 10:38 PM
SRAC76's Avatar
SRAC76
Attached a PDF that might help.
Old Jun 28, 2018 | 02:25 PM
dptropepe's Avatar
dptropepe
Thanks for the PDF. It helped a lot. I have B+ on the orange wire on the TPS. Max volts should be no more than 4.6 at WOT. Where is the most likely place that is feeding voltage to this wire?
Old Jun 28, 2018 | 03:46 PM
Look at what wires are close to it at the PCM connector, and what voltages they should be carrying...... I think most of the sensors get their 5 volt reference signal from the same place... and that will REALLY confuse the PCM.
Old Jun 28, 2018 | 10:00 PM
dptropepe's Avatar
dptropepe
I have the 5 volt reference on the violet wire. I have a good ground at the blk/lt blu wire. The orange wire has full B+ KOER. What feeds the orange wire?
Old Jun 29, 2018 | 07:56 AM
Orange wire goes from the sensor, to the engine controller. I don't really see anything that should feed that circuit 12 volts..... gotta be a bad wire in the harness somewhere, or, the controller is internally shorted.
Old Jul 1, 2018 | 10:20 AM
dptropepe's Avatar
dptropepe
Hey You is right. The orange wire is getting fed B+. I cut the wire at the sensor and the PCM connector. I ran a wire between the sensor and PCM connector. The light is out and the truck runs like normal. Now I have to find the fault. Thanks for the help.
Old Jul 1, 2018 | 11:15 AM
RalphP's Avatar
RalphP
You'll have to run the wiring harness to find the short somewhere. Might be another sensor on that line that's shorted to 12V somewhere.
If you don't have it, locate the factory service manual so you can have the wiring diagrams you need to trace the wiring properly.
RwP
