How to remove rear wheel bearings and seals
Old Jul 21, 2018 | 07:50 PM
dakootie's Avatar
dakootie
Default How to remove rear wheel bearings and seals
Image one seal removed the hard way, the round steel bar is long enough to reach through the pumpkin spider gears and connect with the backside of the other wheel bearing on the far side.
A few light taps with the heavy sledge, both the bearing and seal pop right out of the housing.
You do not need to use a sledge, just happened to be handy.
Old Jul 21, 2018 | 09:27 PM
dakootie's Avatar
dakootie
Do you think this will work for installing the new bearing.
Place an old bearing onto the axle followed by the new one, tap end of the axle to insert bearing.
Or place the new bearing in the freezer for half an hour then heat the housing up to warm to the touch not sizzle spit hot. New bearing should fall right into place before warming up.
