Help with a build sheet
Old Nov 3, 2018 | 11:11 PM
Azboyinmi's Avatar
Azboyinmi
Default Help with a build sheet
Need some help guys. I've tried all the links for build sheets. I'm just not having any luck. I need the sheet to order carpet and interior parts etc. Plus it would be nice to have.
any help would be amazing
Here's the VIN
Old Nov 3, 2018 | 11:26 PM
RalphP's Avatar
RalphP
Here's the VIN
That's for a 1993?
They only supply 25 years back if I remember correctly; that would be a 1994.
Sorry, but you're probably out of luck by now.
RwP
Old Nov 3, 2018 | 11:45 PM
Azboyinmi's Avatar
Azboyinmi
Gee thanks for bursting my bubble Ralph. Lol.
i emailed Dodge and requested one. Hopefully I'll get lucky
Old Nov 4, 2018 | 12:16 AM
RalphP's Avatar
RalphP
But, you know, you don't NEED the build sheet for most of that.
The 1993 parts list (1990-1993) is in the FAQ; download that, you can get the original part number for whichever color your interior is (and you can get THAT off the tag under the hood!), and presto, instant compatibility.
Or as compatible as aftermarket can be ...
Me? I'm painting the interior plastic for the dash and the A and Cab Rear pillars navy blue, to complement the Pacific Blue seats; what Mother Mopar did in 1987 when she built my Dak doesn't really matter that much to me
RwP
Old Nov 4, 2018 | 01:42 AM
Azboyinmi's Avatar
Azboyinmi
Yeah....that tag.... Non existent lol. Ive got 3 hoods from 3 trucks including mine and only one has a tag and that truck is a diff color, diff color interior, 2wd v6 single cab 91. So..... Yeah
Old Nov 4, 2018 | 09:28 AM
Isn't the tag in the glove box as well? (at least, the option code sticker??)
Old Nov 4, 2018 | 10:05 AM
Azboyinmi's Avatar
Azboyinmi
My 02 had one in the glovebox, but this truck doesnt
Old Nov 4, 2018 | 10:40 AM
onemore94dak's Avatar
onemore94dak
AZboy I found my old email build sheet from 2014. It has a reply by link only in it. Since I didn't have an email for them and any reply on that link page would come to me
I replied and mentioned that you were looking for your build sheet & posted your VIN and well it usually takes a few days for a reply. I should hear back by Friday.
Old Nov 4, 2018 | 11:48 AM
Azboyinmi's Avatar
Azboyinmi
Thanks man I appreciate it. It would be awesome if I could get everything figured out
Old Nov 4, 2018 | 12:38 PM
RalphP's Avatar
RalphP
My mistake. My Cougar has it on the core support; on the Dakota, well, for 1988, from the factory service manual: "The location of the body code plate on this vehicle is riveted to the floor plan under the carpet and seat on the passenger side."
Checking the 1996 FSM that I downloaded from here, I find it's in the same place; THAT manual has a drawing. (For 1996, it's page 2 of the manual downloaded from here.) From that, I'd presume it's in the same spot on a 1991; that's a presumption, however - check your copy of the the 1991 FSM to match.
That'll give the code; the parts lists (also downloaded from here!) will tell you what that color is called.
But for 1991, the color codes and color names mentioned for a Dakota are: T7 Tundra, R8 Bordeaux, M6 Crimson Red, S8 Charcoal, and TT Spice .
Hope this helps some! (Also, there's ... not that many choics. Should not be hard to locate your original color in that list.)
RwP
