Drivetrain vibration / rumble
Like I said I don't really know where that came from but never had any intention of keeping it.
The point I was trying to make was regarding failure and replacement. If in fact the GMB joints were/are not original, and I'm not saying they aren't although Don is, it means that at some point the alleged OE installed Spicer joints in that driveshaft failed and were replaced wholesale by GMB, which is, in my opinion, a pretty big leap of faith.
I can (and will) do a random survey of JY Dodge Daks next time I'm there. It's relatively easy to check and see who made the joints on trucks in a JY which are off the ground. And, the statistics are valid when the reason your group is there has nothing to do with the content of the survey...and it does not. So we shall see...
Thx
Steve
Random question that surprisingly hasn't been brought up. Have you checked your pinion angles at all? It's not hard or time consuming to do. But if something isn't right it can actually cause the vibration you're talking about as well as cause the brinelling on your u joints. I just rebuilt the entire rear half of my truck, down to bare metal on everything. I checked the setup of my rear end before I started and all the angles were off by a decent amount and after tearing apart ujoints I found that the u joint at the trans had a fair amount of brinelling in them and they were clean and we'll greased. Now my rear end has been set up perfectly which did take some extra work but I plan on my truck being on the road still in 30 years so it was worth the effort.
some parts stores carry the angle finders for drive line setup and will rent them out to you.
With all due respect the OE installed joints were GMB and I believe they are identical to the ones I used as replacements. If they were junk then the ones I removed, at 167k miles, would have been trashed, but they weren't. As I said there was a tiny amount of brinelling at the pinion joint but otherwise perfectly serviceable
But I did sped red *sic* and missed the "Yes, I assumed that, the damaged joint is obviously not being kept." line. I apologize.
RwP
As for the intake, that too is something that will come later. I will do the extensive TB cleaning soon but the intake has to wait. The truck is actually running very well now, really well. And now since I have a working fan clutch it's not roaring anymore either! Woo hoo for that one, the good clutch came from a 2001 Dakota 3.9L.
So now I'm on to cleaning the TB, which might help with the idle control problem, and then I will probably start in on making sure the door weatherstrips are good and then start in on getting the floor fixed up. This truck had some water leak issues before I got it and I want them resolved before putting it on the road in the winter. I also need to install the forward parking brake cable since the carpet is out and I need to replace the aftermarket radio with a factory unit from the junk yard.
Also considering all new tires all around. I had bought some used ones to replace the bald pair but the rear tires were dated 2010 and didn't look too bad. I'm not all that happy with the setup and I might splurge and have new tires put on all around, that is if I'm convinced I don't have a bent wheel....
Thanks for all the tips guys
Steve A
RwP
I can shift into neutral while traveling down the road and the vibration / noise continues on at the same level. I'm beginning to wonder if it's rear axle bearings but since I've never experienced that I couldn't say. I have a friend across the street who arguably has more experience with RWD vehicles, he'll drive it tomorrow.
Odd though, I can feel it a bit through the steering wheel at road speed and I noticed in park the engine has a vibration around 2500 rpm that I didn't notice before. It's not much though.
Steve A
It could be a wheel bearing - but I thought you said you'd had it up on jack stands and the vibrations continued with the driveshaft out.
Ah. Not a wheel bearing, not a rear axle bearing.
Quoting you very early on:
That lets out wheel bearings, TIRES, and axle bearings. Also let out the differential. NONE of that is in motion while up on jack stands.
If you split the front yoke off, and put it in the transmission (to keep it from bleeding out), do you get the vibration still?
With it up on jack stands and with the entire driveshaft out?
RwP
I have put it up on jack stands and run it and even with tires off (and drums bolted down) it still comes on. I have pulled the rear driveshaft and it's better but still there, and I have no reason to think that the driveshaft is bad and the u-joints don't seem to be bad on the rear shaft.
RwP
RwP
RwP
Have not split out the yoke but might do that. I'm taking the driveshaft in for balancing tomorrow, if only to prove my neighbor wrong. He didn't seem to want to listen to what I said and kept repeating to me things that I was categorically telling him were false. He claimed that the vibration went away when he shifted into neutral at speed when in fact it does not. He then said that if the driveshaft was not the culprit then he was saying transmission although when I am driving at 60 and I put it in neutral and let the engine Idle down I continue to hear / feel the vibration so that tells me at least that it's not a load issue and it's also not likely to be transmission.
When I ran the engine with the rear half of the driveshaft removed there was a vibration but not as much, and it may have been result of the engine and not the actual problem that I feel when going between 30-50/60 mph. The engine does have a vibration at about 1600rpm (I think) when in neutral and just revving but that vibration is not nearly enough to cause what I'm feeling during actual drive, and it wanes once it gets closer to 1800 rpm.
I am still of the belief that the rear axle bearings might be the problem but I haven't investigated it further, but tomorrow after the driveshaft balancing ends up being a wasted effort I will move in that direction. I don't really think that the transmission is the problem when I can shift it into neutral and the vibration / noise continues on at the same level while the engine moves to idle speed, that is just not consistent with a transmission problem.
Thanks Ralph!
Steve
