Edelbrock fuel injection
Old Jan 22, 2019 | 02:05 PM
RalphP's Avatar
RalphP
The edelbrock system is TBI, isn't it? With the LA style distributor, that may be all you need..... I don't think it cares about cam sensor signal. After all, the LA engines never had one......
Whereas the injectors are in the throttle body, they're related to the factory TBI about like your Dakota is related to a 1880s Conestoga wagon
Depending on the model and version, most of the aftermarket "Carb Style" injectors use the tach input off the ignition as a cam and crank sensor (figuring out which is which by the signals).
https://edelbrock-files-v1.s3.amazon...t2-install.pdf for one example.
RwP
Old Jan 22, 2019 | 02:06 PM
RalphP's Avatar
RalphP
Originally Posted by Azboyinmi
The system he's running is this, but for Chevy so I'd have to probably pay to get the la maps for the computer.
the la kit I looked at was mpfi and came with everything, intake, tb, rails, injectors, o2 bung and sensor, coolant sensor and adapter, harness, fuel regulator, 7inch window mount tablet, etc
I'd go this way; even if you kept the factory kegger intake (if it'll work with that), you'd be well and far away better.
Shucks, you got an O2 bung; you could have that one welded in for a wide band for a gauge in your instrument panel!
RwP
Old Jan 22, 2019 | 02:18 PM
Azboyinmi's Avatar
Azboyinmi
Personally I'd like to take my kegger intake out back, fill it full of tanerite and hit it with a couple .308 incendiary rounds and watch it make a crater in my back yard. They suck and nothing anyone has done to one makes any difference at all.
not to mention no it won't work, has to be a 4 barrel mount. That's why I mentioned the m1
Old Jan 22, 2019 | 03:02 PM
RalphP's Avatar
RalphP
Don't destroy it - Marty Fletcher has figured out a way to make the kegger shine.
Or so early dyno results say ...
RwP
Old Jan 22, 2019 | 04:02 PM
Azboyinmi's Avatar
Azboyinmi
Is there a write up
Old Jan 22, 2019 | 04:11 PM
RalphP's Avatar
RalphP
Is there a write up
http://utawesomeperformance.com/kegger-vrp.html
RwP
Old Jan 22, 2019 | 04:46 PM
Azboyinmi's Avatar
Azboyinmi
Huh,
very interesting. I may have to try that. I do have an extra manifold......hmmmmm. ahh well ideas for the future
