1995 2.5 Fuel pump rollover valve
Can anyone out there help me with the issue I have finding the correct rollover valve for my new fuel pump. I cant find it anywhere. I dont want to remove the old fuel pump and put the new one in until I can replace the rollover valve. People say they break off easy.
If you are replacing the whole assembly then use some lubricant gently pick up the end of the hose with a small screw driver and get it in there. Before trying to pull the hose off twist it so that it is not stuck.
I looked on Rock Auto and it shows that the assembly is the same. Here is the fix someone figured out.I have an "extra" pump I did it on. https://dodgeforum.com/forum/1st-gen...fuel-pump.html
