1995 Dodge Dakota not getting fuel out pump I beat on tank then it fires up shut truc
Old Feb 26, 2019 | 07:43 PM
David Norris1989's Avatar
David Norris1989
Default 1995 Dodge Dakota not getting fuel out pump I beat on tank then it fires up shut truc
I beat on tank truck fires back up shut truck off won't start again any help plz n I can't find OBD2 port
Old Feb 27, 2019 | 10:11 AM
95 is OBDI.
Not real clear what your issue is though....... Try posting in the first gen dakota section.
Old Feb 27, 2019 | 02:25 PM
onemore94dak's Avatar
onemore94dak
The OBDI port is on the passenger side firewall.
read through the FAQ section on fuel pump issues and search fuel pump issues on here. You will find a lot of possibilities for things to test and it may help you describe your problem to us better.
