95 2.5l crank/no start
Ok so here’s everything I’ve done so far
Will crank but no start
•New plugs and wires
•New cap
•New coil
•New air filter
•New head gasket, intake manifold, and exhaust manifold gasket
•New fuel filter
•New thermostat
•New relays
•Timing done
•Replaced ASD relay
*DOES NOT HAVE FUEL PUMP RELAY
i cant keep dumping money into her. Any help is welcomed and appreciated
•New cap
•New coil
•New air filter
•New fuel filter
•New thermostat
•New relays
•Timing done
•Replaced ASD relay
There is a 95 factory service manual in the FAQ section.
A code 42 doesn't just mean the ASD might be bad. It could be something else in the circuit.
http://www.dakota-truck.net/CODES/codes.html
