Spare tire extension tube
my spare doesn't lower very easily. The tool that inserts mostly spins unless I really hammer it in every few turns. The part doesn't show up on RA
I'm not sure how to read the parts manual it lists 3 with a measurement next to a W.B. 1994 124: W.B. and 1994 112", 131" W.B., (224mm Long) The 3rd one is 95/96. and all 3 have different part numbers.
How do I figure out which one I need. Then if you know where to get one please let me know.
That said - if it's hex drive, you can find hex drive bits to fit a 1/2" drive ratchet and extension; if flat, a 1/2" wide flat tip bit to fit said ratchet and extension will also work.
RwP
RwP
Well that part number came up for 1989 with the right WB but I wasn't sure. I found a Mopar Parts Giant ad for the same part on a 95 and its wiki said it would work on mine. I called the dealer who told me mine was NLA and could not tell me if the 95 part would work.
yada yada yada I ordered the 95 part and I will see if it works. Plus even with shipping the 95 part was $19 bucks cheaper before shipping on the 89 part. The 95 part #52058545
