headlight wiring connector
Old Aug 18, 2019 | 12:31 PM
93 ragtop's Avatar
93 ragtop
Default headlight wiring connector
Has anyone seen a male connector that would plug into the factory headlight connector? I am setting up my headlights to run off of 2 relays.... And I could make up a harness that would be a direct plug in rather then cutting and splicing....
If not, I could use 3 male spade connectors, but would rather find a 3 prong male connector that would plug into the headlight wiring...
Thanks
Old Aug 18, 2019 | 02:10 PM
RalphP's Avatar
RalphP
Is this for the sealed beams, or the Aero style?
If sealed beams, what I did was cut apart one of these:
https://www.amazon.com/GENSSI-Headlight-Conversion-Wiring-Adapter/dp/B007AK9M66/ https://www.amazon.com/GENSSI-Headlight-Conversion-Wiring-Adapter/dp/B007AK9M66/
Alas, that's just the male; if you need both, you may want to check https://www.walmart.com/ip/Handy-Pac...ctor/170264581
If Aero, then the 9004/9007 style connector ought to be easy to find; I'd look at
Amazon Amazon
. Cut them up and you have both the plug and two sockets for the 9004/9007 type lights.
Just to remind you - be sure to fuse as close to the battery as possible! I have a fuse block I use under my hood; low beam / high beam / sub are the three current fuses.
RwP
Old Aug 18, 2019 | 02:14 PM
93 ragtop's Avatar
93 ragtop
Hey Ralph, I figured if anyone knew, it would be you!! Now, for my problem, I cant open the first link. BTW its the 87 so its sealed beams...
Old Aug 18, 2019 | 02:35 PM
RalphP's Avatar
RalphP
Links fixed. For some reason, the third paragraph was bonded to the link in the second by the web site ... and I didn't proof before I saved!
RwP
Old Aug 18, 2019 | 04:37 PM
onemore94dak's Avatar
onemore94dak
I was looking for fog light assembly from teh FAQ link and I ran across these earlier https://www.partsgeek.com/catalog/19...g_harness.html
