Control arms
Old Oct 1, 2019 | 07:27 AM
Andrew Clee's Avatar
Andrew Clee
Default Control arms
I'm running a 95 slt 4wd 3.9L. Can I use the control arms from a 97 if I change the knuckles out
Old Oct 1, 2019 | 03:47 PM
93 ragtop's Avatar
93 ragtop
I tried to replace the uppers on my 87.... The control arm seemed to be the same.... but the balljoint is different. If you do the knuckles, I have no idea, if the rest will work with it, ie. axle, brakes, tie rod ends shocks etc.
Old Oct 1, 2019 | 06:17 PM
Andrew Clee
Thanks
Old Oct 3, 2019 | 05:50 PM
volaredon's Avatar
volaredon
87-96 will interchange. 97 is different.
Old Oct 7, 2019 | 10:05 AM
Andrew Clee
I am aware of this. Mostly wanted to know if there is a way to swap out or retro fit newer suspension.
