Limited slip diff
Old Dec 16, 2005 | 01:07 AM
Dakota Brad's Avatar
Dakota Brad
Default Limited slip diff
hey
i have a 94 dakota 2wd with limited slip diff, lots of the time i only have 1 wheel wounder, why does my limited slip diff only work half the time? its pissing me off, i am always getting stuck now with out it, but when it was working it was awsome
Old Dec 16, 2005 | 01:55 AM
360DakotaPwr's Avatar
360DakotaPwr
Default RE: Limited slip diff
Its probably worn slam out. Dont worry, your not the only one with this problem.
Old Dec 16, 2005 | 07:50 AM
Dakota Brad
i owed the truck for about a month, and it worked awsome for about 2 weeks then i pulled out my parents 94 GMC 3/4 truck with the dakota then after that it hasnt been working good, it still works sometimes
Old Jan 13, 2006 | 07:13 AM
Dakota Brad
today i took off the diff cover and the gears looked good, there were no shavings,
Old Jan 14, 2006 | 07:07 PM
360DakotaPwr
Wait a sec. If I remember corectly LSD was not offered until 1997. If your lucky, sometimes both wheels will spin, but not likely. The right rear drives the truck for the most part. Get a 97 up, it will have a tag on the cover with LSD stamped in it, buy new spring and shock perches, weld them on, and your ready to go. All the brake parts interchange.
Old Jan 15, 2006 | 02:37 AM
Dakota Brad
It was offered in 94, in the manual for the truck it saids it was offered, and on a tag on my hood it said LIMMITED SLIP DIFF
Old Jan 16, 2006 | 01:48 AM
360DakotaPwr
Well your lucky my friend. I would say the clutches may be worn out then. If this is so. you wouldnt necessarily see metal shavings or anything. They arent really a metallic material.
Is there a tag on the rear axle itself by any chance?
Old Jan 16, 2006 | 05:17 AM
Dakota Brad
how much work is it to replace the clutches? i'll take a look 2morrow and c if theres a tag
Old Jan 17, 2006 | 03:04 AM
360DakotaPwr
Well I know many things about Dakotas, but rear axles are no specialty of mine. I know yo have to pull the axles out, probably c-clips, or the backing plates hold them in. I don't remember. When you take it apart though everything has to be properly shimmed before it is put back together. This job is really for someone who knows what they are doing. Besides you don't want to spend $ on parts and have it not work.
Old Jan 17, 2006 | 06:25 AM
Dakota Brad
I guess i'll just look for another one from a wrecker, what years did they start using the limited slip diffs on the 1st gen dakotas? what did they usually come with the 4 cyl, V6 or V8?
