96 Dakota tie rod torque specs
Old Dec 21, 2019 | 03:40 PM
r96dak's Avatar
r96dak
Default 96 Dakota tie rod torque specs
Hey guys,
Anyone either know of or where i can get the torque specks for inner and outter tie rods for a 96 2 wheel drive at?
Thanks.
Old Dec 21, 2019 | 04:20 PM
RalphP's Avatar
RalphP
Originally Posted by r96dak
Hey guys,
Anyone either know of or where i can get the torque specks for inner and outter tie rodsfor a 96 2 wheel drive at?
Thanks.
I dunno, but I'd look at pages 19-15 in the FSM for the outer (hint: 44 lb/ft) for the castle nut and the jam nut. For the inners, I do a single "UNGH" with the open end wrench and LockTite Is Your Friend.
(The FSM can be downloaded from the link in the FAQ. I'd HIGHLY HIGHLY recommend downloading it ... )
My 1988 shows the inner at 70 lb/ft, but use a 32mm open end to back up on the rack itself, so you don't twist it and damage it.
RwP
Old Dec 22, 2019 | 08:17 AM
r96dak's Avatar
r96dak
Thank you @RalphP very much sir.
Old Dec 23, 2019 | 01:31 PM
volaredon's Avatar
volaredon
As an alignment guy I changed hundreds of tie rod ends over 20 or so years, and never once put a torque wrench on one. Never had one come apart or strip out either
Old Dec 25, 2019 | 09:40 AM
r96dak's Avatar
r96dak
As a non mechanic guy that makes me feel better lol thank you.
And Merry Xmas to everyone.
Old Dec 25, 2019 | 10:32 AM
volaredon's Avatar
volaredon
just remember... on the outers you will probably think "tight enough" between 2 slots of the castle nut for the cotter pin. NEVER loosen to get to the next hole, tighten to next hole "the other way".
Old Dec 25, 2019 | 05:05 PM
r96dak's Avatar
r96dak
Gotchya....have read this also over the last few days myself thanks.Of course i've waited 2 days for the weather to clear and the water under the truck to to drain to get these things swapped out,but after i got the boot off i realize the inner tie rods on the truck don't have the slots on them,they are just round.Can't find my pipe wrench to try that.Guess it's another day to wait until the stores are open to buy another tool.
Old Dec 25, 2019 | 05:12 PM
RalphP's Avatar
RalphP
No vise grips either?
That's what I used last time.
RwP
Old Dec 25, 2019 | 06:43 PM
r96dak's Avatar
r96dak
RwP
I own 2......little one and a bigger one.The ones that'll fit are in my daughters trunk and she's visiting out of state for the holidays.Kinda glad,who wants to do tie rods on christmas.
Good to know though that vice grips alone will work.I'm still a little ticked i can't find my pipe wrench though.
Old Dec 26, 2019 | 07:03 PM
r96dak's Avatar
r96dak
Ok so after borrowing a pipe wrench from work and breaking my inner tie rod loose i discover that the tie rods on the truck DO have slots on them for a normal tie rod tool.What i'm not under standing is why my rack doesn't allow me to use the standard tool??
I wasn't even able to use the tool i rented to put the new one back in.The slotted/flat section has to go into some what of a sleeve i guess we'll call it leaving only the rounded end exposed to work with.
I did as suggested and got it pretty tight with the pipe wrench.
I just found it odd that the tool was useless.
