Flywheel size difference between V6 and V8?
I apologize for starting another thread, but I have one more question regarding my 3.9L to 5.2L swap. With my 3.9L V6 right now, I have an AX15 transmission, and I know that with the V8, I'll need a new flywheel with the right tone ring, plus, I want to replace the clutch anyway. From what I'm finding, the V8 flywheels are slightly bigger, about 1/4" larger in diameter. Would this be an issue with the stock bellhousing and starter location? I'm thinking it would fit okay, but will the starter need modification? Maybe I would be able to find out once I pull out my V6, but I'm wondering if anyone would know, before I do that.
For reference, here's a link to a V6 flywheel:
http://atpautomotive.com/flywheel-z-324
V8 flywheel:
http://atpautomotive.com/manual-tran...flywheel-z-368
Also, any chance anyone knows the true stock flywheel size?
Rockauto is a bit confusing with this, because it seems that every flywheel manufacturer is measuring the diameter differently...
V8 flywheel:
