Dome light
I don't see how the key being in would make a difference ...
See the attached PDF with the wiring for the dome light.
But, you may have bad switches in the door jambs (which ground the light to turn it on).
EDIT: How about the halo light at the ignition switch, the glove box light, and if you have it, the courtesy light under the dash on the passenger side?
RwP
RwP
