Replacing lock cylinder on 1988 Dodge Dakota
Old Apr 16, 2020 | 07:52 PM
blackbird308's Avatar
blackbird308
Default Replacing lock cylinder on 1988 Dodge Dakota
Hi all,
I lost my only key to my 1988 Dakota. So I ordered a new key and cylinder. Replaced the door locks, took a while to figure out, and it was a real pain, but made it through.
Tons of information out there on 1992+. But unfortunately for me the 1988 dakota is much different that the 1992 dakota in many different ways.
Now for the cylinder. I can't just pry the cover off. I pulled the air bag, and the steering wheel. I removed the 3 screws on the turn signal switch, along with the bolt going to the lever, got that out. Got the hazard indicating lamp unscrewed along with the hidden screw underneath it. But not im stuck, the yellow plastic backing that the turn signal switch mounted onto won't come off. It's like it's pressed in or something. I found a snap ring that was really hard to find. I got it off.
Now to remove the actual cylinder.
Anyone know what to do next?
Edit: figured it out, will post a guide later on how i did it. For now im gonna have a beer.
Old Apr 19, 2020 | 10:26 AM
RalphP's Avatar
RalphP
You haven't posted the guide; however, if I may point out, all of that is in the 1988 Factory Service Manual.
The methods for tilt, and non tilt, are different in details.
And both are covered.
May I suggest you spring the $40 or less for one, so you don't have to refigure out how to do what's in it?
EDIT: Also, there's no air bag on a 1988.
RwP
Old Apr 19, 2020 | 12:02 PM
ol' grouch's Avatar
ol' grouch
Originally Posted by blackbird308
Hi all,
Air bag? Those didn't come in trucks until 1994. Has someone swapped a later column in?
Old Aug 25, 2020 | 11:45 AM
nati222's Avatar
nati222
Interested in your solution.
and enjoy the beer!
