1st Gen Dakota Y-pipe
Old May 11, 2020 | 12:00 PM
Peadar's Avatar
Peadar
Default 1st Gen Dakota Y-pipe
Where can I find a Y-pipe ( 'engine pipe'/manifold to cat pipe) for a 3.9 V6 Dakota?
No luck with the usual catalogs I have sourced exhaust parts from in the past.
Thanks,
Pete.
Sorry I forgot to note that it is a 1991 (duh) 3.9.
Last edited by Peadar; May 11, 2020 at 12:10 PM. Reason: Left important information!
Old May 11, 2020 | 02:53 PM
RalphP's Avatar
RalphP
Well, first you build a time machine ...
Back in November 2018, I picked up the very last Y pipe that MagnaFlow had anywhere in the USA/Canada for a 87-90 (and that was wrong; it was an 87 only! But I was able to have it modded to fit); Walker was already NLA and disappeared earlier in 2018. I just got it on about three weeks ago; MAN it sounds good! But I digress ...
You may have to find someone who can custom make one from your old one.
EDIT: From the parts list I downloaded a while back from the FAQ, it's a Dodge # 52004224 if you go Googling for one as NOS.
RwP
Old May 15, 2020 | 07:44 PM
s/w theo's Avatar
s/w theo
I got one last year for my 95 V8 Dakota from Jegs or Summit, I forget which. It is a mandrel bent piece from JBA, & I think the V6 & V8 are the same. It was just under $200 but a nice 2 piece unit. Try either one of those.
Old May 16, 2020 | 07:48 AM
Peadar's Avatar
Peadar
S/W theo - this is helpful - I reckoned the pipes would be close to the V8 application by the configuration of the V6 exhaust manifolds - the " 2 piece " assembly with the passenger side exit will make any re-configuration/adaptation of the pipe(s) in my 91 V6 application possible, with a reasonable amount of work.
Thank you very much for the information,
Pete.
Old May 16, 2020 | 10:11 AM
onemore94dak's Avatar
onemore94dak
I looked at the Jegs and the Walker Y available on RA for the 94. I'd stick with the Walker myself. Considering the cost is less than 1/3rd. https://www.rockauto.com/en/catalog/...ion,pipe,10038
This is the only Y pipe for dodge I could find on Jegs https://www.jegs.com/i/JEGS/555/31020/10002/-1
Found this on Summit Stainless https://www.summitracing.com/parts/j...e/model/dakota
I don't know that any of them would fit since afaik the 91 was a 3 inch exhaust from the manifold.
Old May 16, 2020 | 06:05 PM
s/w theo's Avatar
s/w theo
I looked at the Walker "y" pipe too, but too many kinks (compression bends) in the pipe, but it will be ok for some.
Old May 16, 2020 | 10:39 PM
onemore94dak
The 2.5" is way better than teh 1.5 beat up tube that was on there. You can't beat the price and I did the whole thing to tailpipe for less than I was quoted for a CAT in the shop.
Old May 16, 2020 | 11:15 PM
Cmcs24fan's Avatar
Cmcs24fan
Got An extra one stock. Of thats what your looking for
