broken control arm cant find a new one
Old Jun 8, 2020 | 05:16 PM
Donovan Kempf's Avatar
Donovan Kempf
Exclamation broken control arm cant find a new one
hi ive got a 96 Dakota and i need to know if i can use a newer pass upper control arm because they have discontinued the one for the 96's mines a green Dakota sport 4x4 5.2 magnum bought is for 400$ because a tree fell on it and im using it as a farm use/adult go-kart and i broke the pass control arm can i use a newer control arm since i cannot find the old ones
cant find it on 1aauto rockauto or anyother place
Old Jun 8, 2020 | 06:01 PM
Look on the used market. Car-Part.com
Old Jun 8, 2020 | 08:04 PM
RalphP's Avatar
RalphP
What HeyYou said.
Also, plan on new bushings and ball joints to rebuilt it.
I'd order both; rebuild both at my leisure, and then swap them.
Now - personal preference - So far my ProForged brand ball joints are holding up fine. My EnergySuspension control arm bushings squeak every so often if I forget to silicon spray them every so often; if you go poly, I'd recommend Prothane black (possibly ES black also) since Prothane uses graphite in their poly mix to keep the squeaking down.
RwP
