Won’t start
1995 3.9 won’t start no check engine light. Was running and cutting out / dying ... changed pickup in distributor,,, cam shaft sensor ... and coil ,,, for awhile I got the check engine light to come back on by wiggling pin connection at computer but now nothing ,,, is my ecm shot ? Any advice appreciated
Before thinking the ECM is shot, since wiggling the connector helped, I'd start off first cleaning the contacts - easiest is to
1) Disconnect the negative battery cable at the battery.
2) Disconnect the connector at the ECU.
3) Reconnect the connector at the ECU.
Repeat 2 and 3, a total of 3 or 4 times.
4) Reconnect negative battery cable.
That will wipe and polish the connectors, to knock down corrosion and oxidation on them; this will help if the problem is that there's corrosion and oxidation on the contacts (and let's be honest, it's 25 years old now!)
I'd also check on car-part.com and hollanderparts.com to see if I can find an ECU near and cheap, or shipable and cheap, for a swap.
RwP
RwP
Thanks I will give that a try. I haven’t been able to locate ecm yet but I havent looked too hard yet. I did clean every ground I could find in the engine area hoping it was something like that. I will let you know what I find out. Thanks again
Blackish box, passenger inner fender.
How did you shake the connector if you didn't know where it was?
But for the pins - there are depinners/repinners available.
Alas, the one I swore I used, another person here had severe fits with ... so I'd have to recommend one of the big assortments to see which one works for you. Something like this set: https://smile.amazon.com/Terminal-Re...dp/B07V618SJQ/
Also, it helps if you have a bright light so you can see where the retaining tabs are.
Look at the thread https://dodgeforum.com/forum/1st-gen...o-start-6.html for some information.
RwP
Ah. Wasn't clear from how you said that.
If nothing else, check car-part.com or hollanderparts.com for possible replacements (both are aggregator sites linked to multiple wrecking yards)
RwP
RwP
