Late shifting
Old Jun 18, 2020 | 06:42 PM
RWEJR's Avatar
RWEJR
Unhappy Late shifting
My 93 Dodge Dakota LE 5.2 Started shifting out of second into 3rd at 5500rmp so I cleared the ECU gave it a Transmission and filter change now its shifting out of 1st to 2nd hard and 5500rpm with 3rd I read about problems with the Throttle valve cable from others and adjustment I found mine ? When I adjust it in, that is lowering my shift correct if not please help before I tar into it don't wont to make problems worse for myself. thanks for your help hope it make some sense to you. Robert.
Old Jun 18, 2020 | 07:18 PM
RalphP's Avatar
RalphP
It, and the line pressure, set the shift points.
So yes, adjusting it may lower the shift points.
Adjust by the factory service manual, and enjoy. If that doesn't help it, it may be something plugging the lines so you get excessive pressure.
RwP
Old Jun 22, 2020 | 01:51 PM
RWEJR's Avatar
RWEJR
RwP
Hello I think I found the problem my throttle positioning sensor just fell apart so I purchased a new one now I have a worse problem, Installed it to day and the truck idled good at first then went almost to full throttle. Took the sensor off a relined it and it stayed wide open ? what do you think is going wrong it seems pretty strait forward installing. any ideas?
Old Jun 22, 2020 | 03:10 PM
Make sure you are installing the sensor properly. Also, disconnect the battery, turn on headlights, count to ten, turn off headlights, reconnect battery. Turn ignition to On, (not start) count to ten, THEN start the truck. (don't touch anything) That lets the PCM re-learn zero values for various sensors. If it still wants to go wide open, something else is going on, or, you got a bad sensor.
Old Jun 28, 2020 | 04:26 PM
RWEJR's Avatar
RWEJR
HeyYou did what you suggested and the problem is almost fixed thanks for the heads up, One more question now it's coming out of 1st @ 35 MPH and 2nd @ 55mpr, seems to shift hard also have any suggestions of what I can do to fix this problem. First time dealing with a problem like this very kind of you to take the time and helping me. By the way love the name LOL. have nice evening.
Old Jun 28, 2020 | 04:46 PM
Check TV cable adjustment, and that it actually moves freely. Sounds like it is stuck wide open.
