95 SLT air bag warning
Old Jan 7, 2021 | 06:33 PM
skids's Avatar
skids
Default 95 SLT air bag warning
I have a 95 Dakota 5.2L that had an air bag warning problem. When you start it up, the idiot light would come on for about 5 seconds and then go off and then it would come on again and STAY ON. I checked fuse No. 14 which was fine. I disconnected the negative battery terminal for some time and reconnected it, but the problem persisted. So I started looking under the hood. On the right fender near the antenna I found 4 chewed wires. Those wires joined a black plastic connector that was attached to the fender with a plug into a hole. The 4 wires are blue with black stripe, black with blue stripe, blue, and tan. I butt connected those wires and it fixed the air bag warning.
