Seat belt retractor question ?
Old 01-08-2021 | 04:56 PM
2dak's Avatar
2dak
Originally Posted by onemore94dak
Search seat belt cleaning or seat belt retractor (sp?) on YT and there are a lot of them.
My 94 doesn't grab when I pull it out, the old one was doing that like the old ones Ol' Grouch describes. it took almost a minute to get enough out to get it on sometimes. Cold seemed to make it worse. It does grab and tighten while driving when I have to brake hard.
_________Thanks for the information
Old 01-08-2021 | 04:59 PM
2dak's Avatar
2dak
Thanks for the info
Old 01-09-2021 | 07:47 PM
RalphP's Avatar
RalphP
Originally Posted by 2dak
Thanks Ralf. I have another question for you. Regarding the new one that you bought from wescoperformance, Does the shoulder strap lock when you give it a tug with your hand ?
Thanks
It depends on how hard and fast you tug on it. A slow pull and they feed fine. Much of a tug and they lock up. And don't YANK them!
Edit: Had to wait until I got back to the truck and had already fastened the bed down before I thought to check this.
RwP
Old 01-09-2021 | 11:54 PM
2dak's Avatar
2dak
RwP
Thanks Ralph. I may buy it. Another question for you. Are the angle brackets that come with the kit really strong? They dont look obviously heavy duty in the picture
Thanks
Old 01-10-2021 | 12:35 AM
RalphP's Avatar
RalphP
They're pretty stout. Again, that's the mounting kit; it's designed to support a 250 to 300lb human in impact after several years.
RwP
Old 01-10-2021 | 01:05 AM
2dak's Avatar
2dak
RwP
Thanks Ralph
Old 01-14-2021 | 12:47 PM
lator's Avatar
lator
Post
to find out what kind of seatbelts, drive down the street at about 25-30 no more than 35 and slam down the parking brake, the brake lights will not come on so the computer will think you hit something and lock the belts before it picks up the park brake signal light (the instrument cluster is the last thing the computer checks when it thinks there's been an accident) they will only lock for about a second (just long enough for the computer to evaluate whether airbags are needed, determine that there is no body damage(99 or newer), and detect that the parking brake light is on)
I learned this trick from drivers ed, they said to do to when test driving a used vehicle that you want to buy, to make sure the seatbelts work. Don't go over 35 because the airbags could deploy in older vehicles that deploy SRS from sudden stop rather than impact (96 or before)
Old 01-14-2021 | 04:16 PM
2dak's Avatar
2dak
Thanks. I will concider tryng this. My 93 Dakota doesnt have air bags.
Old 01-14-2021 | 09:15 PM
RalphP's Avatar
RalphP
I don't know why Lator is suggesting that; the seat belt lock is only mechnical.
And the computer doesn't check the instrument cluster; for our trucks, it has no IDEA what the cluster is or has.
The ONLY interconnection is the tach; and it's driven off the ECU.
(Speedometer for 94-96 is driven off the VSS, which drives the ECU. Not the same thing as the ECU driving the speedometer.
RwP
Quick Reply: Seat belt retractor question ?
