[89 Dodge Dakota] Wipers not working
Old Jan 20, 2021 | 05:55 PM
RandoRemi's Avatar
RandoRemi
Unhappy [89 Dodge Dakota] Wipers not working
Hello. I have a 1989 2wd automatic dakota. The windshield wipers quit working a bit ago. I swapped out the wiper fuse still nothing. I replace the wiper motor, still nothing.
Then i began checking power to the motor from the plug. All good except one. The green-ish wire (in picture) is not showing any power while all others are. And theres power to the wires going to the actual windshield wiper motor. Im not sure if the green is a ground wire or something to do with the multi-function switch (which im going to replace if i can find a solution)
Im sure some of you are smarter than me on dakotas by far as this is my first one. Please help!
Old Sep 23, 2023 | 11:29 AM
Royal Ryals's Avatar
Royal Ryals
Default Me too
I am having same issue w my 89 Dakota as well replaced wiper motor replace linkage bushings and made sure linkages was together check and changed fuse that didn’t appear bad and now I’m thinking multiswitch or module not sure whitch I should try first
