Need new fuel line
Old Apr 6, 2021 | 05:43 PM
chasebh89's Avatar
chasebh89
Default Need new fuel line
So my 91 dakota developed a slight leak on one of the fuel lines (it's right in the middle of a clip that holds it to the frame so I can't quite tell if it's a feed or return) and I need to patch it. I'm thinking about getting regular high pressure fuel line and running it from the fuel filter, which has a regular nipple on it, to the throttle body, which also has a nipple. I'd rather get a new steel line and fix it properly but I can only find full kits for ~$200. The pressure line after the filter is an easy enough replacement but return lines and feed from tank are going to be difficult.
Any ideas if a rubber line would work fine? The stuff I can get is rated for 220-something psi while the pump only puts out like 45.
Old Apr 6, 2021 | 06:19 PM
RalphP's Avatar
RalphP
If it's a 1991, the system should be at 14.5PSI max unless the regulator's gone bad at the throttle body.
I'd use nylon AND I'd put some armouring around it; I lost the nylon fuel lines on my 1991 Cougar one night when a road lizard jumped out in front of me (chunk of 18 wheeler tire ... at least THIS one was low. One took out my windshield a few years earlier ...)
If you lift the bed, you should be able to put a small bubble flare on the line to give the hose something to seal against, and use new cupro-nickel line (although that also should be armoured; it's not as tough as stainless when rocks fly).
BTW - you STILL should use EFI hose for the fuel line if you go rubber; the regular rubber hose won't like even 14.5psi, much less 45psi.
RwP
Old Apr 6, 2021 | 06:36 PM
chasebh89's Avatar
chasebh89
What about steel brake line? I can flare the ends and clamp rubber on for the filter and t-body (similar to factory). I know pvf and copper line don't like gas but I'm curious is just regular old steel works.
Old Apr 6, 2021 | 07:33 PM
RalphP's Avatar
RalphP
Regular steel does work; cupro-nickel (aka "Nickel copper") is just easier to work.
RwP
Old Apr 6, 2021 | 08:52 PM
RwP
Doesn't rust out as quickly either.
