Random Loss of Power (Fault1 Key-On 29)
Hello!
I've asked a few questions relating to this problem before, but now, I feel like I have some more information available that may help in diagnosing this issue.
First, let me explain the issue. What seems like completely randomly while driving, my truck will lose power. It doesn't completely stall, but if I try to put more throttle, the more power it loses. While this is happening, I can also hear it backfire.
Now, here's some information that may be helpful in diagnosing it:
- Fuel Pressure is fine, especially considering that it's backfiring.
- I've replaced numerous things:
- I've seen online that this issue could be related to a crank position sensor or an ECM. I have an ECM in the mail, since I ordered one from O'Reilly's, but that one was bad. Since they won't give me a refund unless I show proof that I ordered a different one, I had to buy one from a different company, since I don't want to give them my business anymore if I was given a faulty one.
So, to go over it again:
- Fuel pressure is fine
- Not something getting stuck/clogged in the catalytic converter
- Thinking that it's most likely a CPS or ECM.
Thank you so much!
Parker
- Throttle Position Sensor
- Ignition Coil
- Distributor Cap/Rotor
- Catalytic Converter
- There's probably more, but I can't remember at this point.
Thank you so much!
Parker
