1st gen rear end swap info to give
well you see the wheels on that 88 they all have the same cb if you want to get another re for your truck and you want to fix the re that's in it i'm happy for you till you rear end mine cause you can't stop the truck cause your brake suck and you wanted the same center bore but at least you didn't have to buy 6 lug wheels was my point
I don't know what you're smoking, but I'd quit.
Explorer rear ends will have a 70.3mm center bore; Dakotas have a 71.5mm center bore. They're CLOSE, and most Explorer wheels will fit (and the Dakota wheels fit the Explorer as long as they're lug nut centric not hub centric), but ... they're not the same (as anyone who's tried to remove a Mustang or Explorer wheel from a Dakota will vouchsafe for.)
Getting back to traction assist - that wire for the sensor? Is for ABS. Traction Assist is an extension of ABS.
Now, the Explorer could still have been ordered with a TrakLok differential; or a previous owner could have upgraded; but TA <> limited slip differential, so I'd look harder at Explorers WITHOUT the TA button. (I'd also check the tag, and I'd ALSO suggest rebuilding a 20+ year old TrakLok before streeting it myself. But eh; your choice.)
I'm trying to keep correct information.
If that "calls you a liar", well .. maybe you ought to research a bit? Check things out? Maybe, oh, I don't know, learn how to logically think about things?
But your choice.
RwP
if you are finance incompatent like me and you want a quick alternate rear end that is easy to find and will upgrade your stopping power and help you from getting stuck in wet grass here is you a choice if you would like the details on the perticulars you will have to consult other members of the forum but it will work is that better
the most drastic thing that happened to my truck after i installed this re was the fact that the truck would stop cause i didn't realize how under performing the brakes were on the factory dakota brakes
and if giving my personal intake on this info offends your personall smoking habits then far be it from me to interupt a bowl of your politically correct habits just keep smokin your pipe and i'll keep pimpin hoes and smokin crack like apparently i must be doin
if i were to have asked does anyone know a cheap avail way to upgrade my dakota re what answer would i have got i can bet it wouldn't have been an explorer and i'm all ears and pipes on the answer you would give to that question
