1996 dodge dakota 5.2 slt 2 wd
Hello I have been reading forums for a while decided to join since I can not figure out what's wrong
1 sometimes it will go 200 miles no problem or it may make it a block and dies or it will not start at all no power to fuel pump or coil
2 have replaced crank sensor coil cam sensor new fuel pump checked wiring for bad or burned spots wires under fuse box under hood are ok
Can not find a ECM within 5 states Of me could it be a faulty ECM ?
It is a nice straight truck but I'm at witts end about to burn it lol any help would be great
2 have replaced crank sensor coil cam sensor checked wiring for bad or burned spots wires under fuse box under hood are ok
Wright now I can't it's been almost 2 weeks but before if I let it sit a day it would sometimes start but at moment no fuel pump sound installed new fuel pump and you can care it but no coil spark with test light also now you can push throttle to floor check engine light comes on other wise its off with no codes
https://dodgeforum.com/forum/1st-gen...-no-start.html
Ok ill read it yes mine is obd 2 but that is how mine started doing it would start drive it and it was like it lost all power gagues went dead engine would die but for a while it would start Wright back up but not now that's why I was thinking ECM bad
If I had to do it again I would have sent my PCM in for diagnosis from the start. They can bench test those things and pinpoint any problems. From there you can tell them to repair it (if possible) or replace it with a rebuilt. If it comes down to that let me know or read my thread for contact info at the place I got mine. They're not the only ones. Plenty of others who do that kind of work but the guy I dealt with did right by me. But wait for some other opinions on this thread before committing to anything.
Ok will do im still reading your post you linked I never had to deal with one before thank you a lot for your help it's much appreciated
Trending Topics
I'd say it's either bad power wiring (battery cables, that infamous splice, the bulkhead fitting, maybe even the ignition switch itself!) or a bad major ground (see all but the ignition switch).
Good news! The wiring diagrams for your 1996 are in the factory service manual. Better news! After reading this message, go back to the subforum message list, look at the top, the #3 stickied message at the top is the FAQ message. Open it, go about 40% down, and presto, there's a link to where you can download it!
Get that and use that as your map while troubleshooting.
RwP
And to add, I always suspected my OBD1 was the problem with my truck. Before I even posted on this forum. But I subscribe to what Ralph refers to as, "Eliminate what you can, what's left is what's wrong". Or, do the simplest and cheapest things first and work your way to the hardest and most expensive things last. What I didn't know was that removing/reinstalling/replacing an OBD1 and getting it diagnosed was not as expensive or difficult as I thought (an OBD2 could be a different story). And when my hunch all along was that my OBD1 was the problem source, I should have moved that up on my list instead of putting it last. Changing out some relays or inspecting some wiring is easy. Changing out crankshaft sensors, cam sensors, fuel injectors, coils, ignition components, rewiring 60-wire connectors, this test, that test, etc begins to get a bit more difficult and, truthfully, whiffs of a little bit of desperation. My only point is weigh the difficulty + your suspicion of the problem source (OBD2) vs the "cost" of doing all those other things I mentioned and place it appropriately on your "Eliminate what you can, what's left is what's wrong" list. Hope that made sense.
