1996 Dakota problem
Old Oct 13, 2021 | 05:06 PM
Trevorcole's Avatar
Trevorcole
Default 1996 Dakota problem
I'm working on 96 Dakota,it has spark,and I've tested the sensor under distributor cap to verify it is producing a 0-5 volt variation so I assume it is functioning properly......I can dribble some gas down the throttle body and it will start and run as long as i feed it fuel.i replaced fuel pump just to be sure it was good(it had good fuel pressure),but I changed it anyways,the ASD relay is functioning correctly....when I first got the truck,it wouldn't spark either,I found that somebody had put the sensor ground under the positive post of alternator...after I located that issue and moved it to ground where it belonged I was able to pour gas down throttle body and it would run,so I bought the sensor under distributor cap,but it still won't start on its own.....any advice and help would be greatly appreciated
Old Oct 13, 2021 | 05:13 PM
Trevorcole's Avatar
Trevorcole
I'm new to forum,I noticed that I posted this question in wrong section...I apologize,but any advice would still be greatly appreciated
Old Oct 13, 2021 | 07:56 PM
No worries.
Do you have fuel pressure now? Does the pump run at initial key on? and for a few seconds after cranking?
Moving this to first gen dakota for ya.
Old Oct 13, 2021 | 08:12 PM
RalphP's Avatar
RalphP
If it's only missing fuel, have you checked the fuel pump relay in the PDC (fuse box under hood)? That's where I'd be looking with a new fuel pump.
If it's sparking, the crank position sensor (on the back of the passenger head, not in the distributor!) is working.
RwP
