Voltage Regulator?
Old Mar 8, 2025 | 02:36 PM
  #171
GreyGhost.2's Avatar
GreyGhost.2
So I have switched power and power going to regulator, and new alternator installed, have regulator grounded from alternator to fender with paint sanded and bare metal showing, I also ran a ground from the alternator to the battery, with truck running I am only getting battery voltage at the back of the alternator and while running battery still isn't charging, what could be the issue?
Old Mar 8, 2025 | 02:45 PM
  #172
Are you getting anything to the field windings on the alternator?
Old Mar 8, 2025 | 02:47 PM
  #173
GreyGhost.2
Are those the 2 studs on the back of the alternator? If so then all it's getting is whatever the battery voltage is at the time
Old Mar 8, 2025 | 02:48 PM
  #174
If they are getting power, the alternator *should* be working.... Have you tested the alternator itself?
Old Mar 8, 2025 | 02:49 PM
  #175
GreyGhost.2
I haven't tested the new one yet, but with the old one I tested 3-4 times and each time it said it was good, I put a 120 amp alternator in it to see if that changed anything but it didn't
Old Mar 8, 2025 | 03:12 PM
  #176
I would suspect you have the wiring not-quite-right somewhere......
