Tachometer issue in 1992 dodge Dakota
Old 11-09-2021, 09:41 AM
Muffinman2013's Avatar
Muffinman2013
Muffinman2013 is offline
Default Tachometer issue in 1992 dodge Dakota
Hi I have a issue with tachometer the rpm works fine but everything else doesn’t work even the change gears can someone tell me what’s wrong
Old 11-09-2021, 02:40 PM
jkeaton is offline
Dodge Forum Administrator
The tachometer is the RPM gauge. Not exactly sure what is not working. Can you explain more?
Old 11-22-2021, 12:24 AM
SRAC76's Avatar
SRAC76
SRAC76 is offline
So I had this issue after my Transmission got worked on and it turned out to be a cable with a bolt connected to the transmission was loose and dangling. Look underneath on driver side kind of near the backside of the transmission see of it is loose or completely off. I hope this helps!
