1995 Dodge Dakota
Old Jan 26, 2022 | 06:52 PM
Wicked77's Avatar
Wicked77
Question 1995 Dodge Dakota
While driving home the other night the headlights
for no reason turned off and they had been working fine. I pulled on the high beam
switch which turned the high beams on but the only
way they would stay on was if I held the switch all
the way home. Which direction do I need to look
first to fix the headlights. Thanks for any help.
I'm trying to put this truck back on the road.
Old Jan 26, 2022 | 07:38 PM
Ralph4199's Avatar
Ralph4199
Pull the headlight switch from the dash, check the connector. i'd bet there's heat damage.
common problem, you may need a pigtail and a new switch.
Old Jan 28, 2022 | 02:46 PM
bronze's Avatar
bronze
Happened to me a few years back. Turned out the headlight switch was roached. Not a difficult or especially expensive replacement. Follow Ralph's advice above.
Old Jan 30, 2022 | 11:22 PM
Ralph4199's Avatar
Ralph4199
once you sort the headlight switch failure (99% certain this is your issue)
look into a harness conversion kit similar to this:
https://www.ebay.com/itm/143342949942
this reduces the load on your headlight switch by 80-90%, and prevents this failure in the future.
the kit linked is $26 .. if you prefer "name brand" painless makes the same kit for 150-175 ;-)
